Displays the SNMP configuration and statistics on a virtual router.
vr_name | Specifies the virtual router. |
N/A.
Use this command to display the SNMP configuration and statistics on a virtual router.
The following command displays configuration and statistics for the virtual router VR-Default:
show snmp vr VR-Default
Following is sample output for the command:
x670.54 # show snmp vr "VR-Default" SNMP access : Enabled SNMP ifMib ifAlias size : Default SNMP Traps : Enabled SNMP TrapReceivers : Destination Source IP Address Flags 10.120.91.48 /162 32.1.0.2 2ET 10.120.91.48 /162 32.2.0.2 2ET 2001:2001:2001:2001:2001:2001:2001:2001 /16200 2001:2001:2001:2001:2001:2001:2001:20022ET 2001:2001:2001:2001:2001:2001:2001:2004 /16200 2ET 2334:0:0:0:0:0:0:2 /11555 2ET Flags: Version: 1=v1 2=v2c 3=v3 Mode: S=Standard E=Enhanced Notification Type: T=Trap I=Inform SNMP stats: InPkts 0 OutPkts 0 Errors 0 AuthErrors 0 Gets 0 GetNexts 0 Sets 0 Drops 0 SNMP traps: Sent 0 AuthTraps Enabled
This command was first available in ExtremeXOS 12.4.2.
The SNMP ifMib ifAlias size status was added in ExtremeXOS 15.3.
The output was modified to display SNMPv3 notification targets and the notification type in ExtremeXOS 15.5.
This command shows the combined statistics of all VRs in the switch and not specifically for each VR beginning in version 32.6.3.
